Coupe S - Can bring to RR and Shows
Aye, its not far at all. I'll likely be up the garage at that time, so not in banbury. I'll whip the parts off anf you can come grab them if you want. Do you have a sat nav? The village is a little out the way
  • Replies 252
  • Views 11.9k
I can obtain a sat nav lol :)
Struts and hubs gone
Is the glass green tint?
I don't think so no. Have you got a code I could compare too?
It should say on it. In one of the corners there will be some writing on it and if its greet tint it will say tinted on it :thumbsup:
Buff Ting. I'll have a gander. What are you after in particular?
Oi bitch, i PM'd you.... :lol:
This, i need it, desperately. x2
Do you have? Monies involved :lol:
Windscreen, maybe one of the quarterlites too if its the right sort. Solid wing too if you still have it?
Couldnt find any mention of a tint on the glass I'm afraid
Wing still here though
Chody: I just replied on your wanted add B
Carb sold.
Many parts still available
someone just buy this before his missus beats him up
Battery tray any good?
Not really, its had a repair in the past
Hi,
Is the handbrake level assembly in working order? The ratchet has worn out on my Mk2 Couoe and the handbrake won't catch so I'm looking for a complete assembly to replace it with.
I can whip it out providing Kerrly above has found the one he was looking for
Dude can you have a look at the engine harness for me please? See which plugs are on it and such?
If you want. What do you want to know?
Hey mate, do you have a good driver side door for a Mk2 breadvan and a full set of rear seatbelts? I'm in Leamington, so not far away!
I have white drivers door in good nick (not from this car) and I do indeed have the rear seat belts.
i wanna know if i can use a mk2 engine loom in my mk3, just oil pressure, coolant temp and crank and alternator iirc
surely that bit should be the same
Crank? Theres no crank sensors on the mk2 if thats what your after. Or on the mk3 for that matter. I would have thought all the other stuff would be the same. Why do you want to use a mk2 loom?
The starter solenoid wire, causing it to crank over lol ;)
Because I wanna get rid of the EFI loom and thought I could use an OEM loom with the right plugs and lengths
