Mk3 Polo Handbrake brackets
As title, i have the brake bias but not the fittings. Really need rear axle mounts. Also Mk3 Polo hand brake brackets that are fitted to the axle. Might as well just disconnect the cable from the lever and give me all of it.
Edited by kerrly
  • Replies 17
  • Views 1.6k
IT doesn't fit to the axle, it fits to the body work. There is then a spring that attaches to the rear axle via a small roller
Any pics of yours? Cheers
Not the best, but the only one I have. Shows how the bracket attaches to the chassis. Not pics of spring set up, but can get some next week
In the bottom left of the pictures you can just see the curved bracket thats attachd to the rear axle
Edited by prankstar2003
Right well i have the brake bias so i would like everything needed for fitting it please.
Cheers for the help prankstar.
I bought the fixing clips (3 of that attach to the chassis) from vw, as did I the roller that attaches to the rear beam. Not sure about the spring though. Got sent one of those from someone on here p
6) 357612151 brake pressure regulator (load sensitive) ATE / (144 €uros)
7) 867612339 tension spring (1.3 €uros)
8) 867612355 lever (2.3 €uros)
9) 893612363 spacer sleeve (5.1 €uros)
10) 321612367 roller (o.25 €uros)
11) 867612405 retainer (9.95 €uros)
12) N 90031701 snap nut M6X25,9X18 /
13) N 01021226 hexagonal head bolt M6X12 /
14) N 0102376 hexagonal head bolt M8X12 /
15) N 01224110 spring washer B8X15X0,8 /
16) N 0102336 hexagonal head bolt M8X28 /
17) N 01100830 hexagonal nut M8 /
18) N 01167016
If all else fails VW will get a call then, cheers for the part numbers!
Part 8 should be on your rear beam. 11 attaches to the chassis via those wee clips, 12
You never sent me your address for that bracket and the fixing bolts. They've been rattling around in my footwell for ages now :?
Got a 1l mk3 polo fuel pump if you want it
I got a pump now, cheers though.
Still after rear axle brackets and bias bits.
Went to VW and they didnt have anything.
bump
I'm picking up a GT axle soon, but i have no need for the bracket thing. If its on there, you can have it
Message me if you do, not having the brackets has halted my project.
Sorry, I'm talking about the bias srping bracket thats attached to the rear beam. If it has the rear brackets too, I'll let you know
got the bias stuff off 86c now.
Just need rear axle brackets and mk3 polo hanbrake, everything from the leaver back inc the cable and any brackets or fixings.
I've still got the handbrake and the cables, with the brackets that attach it to the rear axle send me a PM if you want it
