Recon engine?
Hey guys. The head gasket recently failed on my Mk2f 1043cc breadvan.
I love the idea of an engine swap, maybe a 1.3 from another mk2f.
Questionis, where is a good place to go to for a recon engine? Or a good condition one at least? You guys had any experience?
Edit: Or maybe a slightly bigger engine from a 6n. Is it much work to get the 6n 1.4 to fit?
Edited by Ben John-Hynes
  • Views 867
why don't you just replace the head gasket, on a mk3 it's not a very hard job if your a novice you can do it easily in a day and a lot cheaper than a recon engine.
If the head is straight its possible to do it in about 2 hours for a first timer.
I've done a head gasket change on the side of a motorway in about 30mins and a year on its still going strong, also handly enough its the same mk2f breadvan I'm planning on buying next week. :lol:
do you actually want a bigger engine?
if you want a recon engine, go on ebay you can get a polo engine for penuts and recon it yourself? a haynes manual and a good set of tools and a couple of days..
heres a AEX from a 6n you mentioned: http://www.ebay.co.uk/itm/VW-POLO-MK4-HATC...#ht_1761wt_1163
Aah right ok, so the head gasket isn't a massive job. Although cam belt kit needs doing too.
Do you think there's a massive amount of work to be done to fit the 1.4? Or will it be relatively simple?
should be quiet a simple change providing you gather everything you need
Legend!
Only arse is the waterpump bolts. But removing the cam pulley gets round this as it has to come off for the head to come off.
