RH 4x100 bolt on spacers
Got these with a set of wheels recently and have no use for them, 99% certain they are h&r. All bolts for wheel to spacer are there but only 8 of the spacer to hub bolts are here but these should be cheap enough to replace
2x20mm
2x25mm
Looking for £75 posted or £65 collected. I'll get some photo's when I get home from work
Edited by Mclovin
  • Replies 17
  • Views 746
If i had the money spare :(
GLWS
Edited by Mattnaz
PM'd you.
If these are H&R and you have at least 8 of the bolts to bolt them to the hub then i will take these posted.
Barney
Cheers Matt. Barney I'll get the photos sorted as soon as I get home :thumbsup:
Hero 8-)
Hmm turns out they are actually RH spacers (makes sense really as they were on a set of RH cups)
One of the spacer to hub bolts is looking a little chewed but torqued up fine when I tried them on my polo
Sorry about the confusion over the make :-(
Least you were 1% right...
Ill take these next week when i get paid if they haven't sold mate.
Right Mclovin has been super helpful with all his replies to me but i am going to stick with my original plans and go with stub axle spacers.
You can tell the quality of these spacers as there is steel inserts in the aluminium where you bolt the wheels to the spacers. This is only on the most expensive spacers. The spacer to hub bolts also have 10.9 strength indicated on the top so none of these chocolate bolts like the ebay spacers.
Bargain really.
Good luck with the sale :-)
Cheers barney 8-)
Also just to add the spacer to hub part is hubcentric and looks to be about 64mm although there are two spigot rings on them taking them down to 57.1, another pair would be a couple of quid off eBay. The wheel to spacer face isn't hubcentric tho as can be seen in the photos, all this does is makes it slightly more fiddley when fitting a wheel :lol:
Cheers barney 8-)
Would you do them any cheaper seeing as there are some bolts missing & hey need another two spigots?
Mark.
They were priced cheaply because the bolts were missing, I'd knock a fiver off for the spigots which is fair as they can be picked up for a couple of quid off eBay with free posting
£65 Posted?
:ninja:
Can you tell me what size the bolts are that need replaced please?
Thanks.
£70 is the lowest I'd go posted as its not just postage costs but no doubt also paypal fee's I'd have to cover. I've already been offered £65 and turned it down, sorry.
The bolts that are missing are 1.5" tip to tip
Had a little mess about with these earlier and if anyone wanted to they could modify normal wheel bolts to work with these easily. The top of normal tapered bolts only just sit proud of the spacer on the 25mm ones so skimming a little off the top of the bolt would allow in to sit inside nicely (there is already a hell of a lot more meat on them than the original spacer bolts). Then they would just need a bit taken off the thread end to make it the correct length.
Couple of photo's to show what I'm on about
So a cheap way to use these would be to use the original spacer bolts on the 20mm one's then use modified original bolts in the 25mm one's.
Thanks for the info, understand about the costs, i would have been happy to do a bank transfer with a long standing member such as yourself.
I'm not 100% which route I'm taking wheel wise now as a set that had been removed from the market may be back up for sale, if thats the case then i wont need these.
You are right about skimming standard wheel bolts down, but i would be dubious about trimming the thread end down as you could mess the thread up and not get them in.
If these are still here and i need them i will be back in touch, glws mate.
Any offers on these? Could do with freeing up some space and some cash :thumbsup:
Edited by Mclovin
Still got them if anyone is interested
Sold to me :)
Yep sold matt, enjoy 8-)
