polo gt mk2-3(spain). how can i tell if it's 75bhp?
hi, i'm a complete noob. i have recently been been thinking about buying a cheap car but i want something a bit different from the run of the mill rubbish. i'd like some thing cheap to run , nippy, reliable with a bit of charm. searching the ads here in Spain i noticed quite a few polo gts (mk2-3) for sale at a reasonable price (1300€ and less). most looked in quite good nick (although that doesn't mean much!). my questions are the following:
1. how can i tell if the engine is a gt 75bhp or gt 55bhp one? i believe in europe there are 2 versions. one just trim and one with a 75bhp motor (or could it be 85bhp. i've seen some advertised as such). the only mods i'd consider would be better brakes and wheel trims.
2. what should i look for when view cars (bearing in mind i'm looking to find a car to keep in original condition)? i mean what problems should i look for? (i'd probably take a mechanic with me as i know next to nothing)
3. i'm looking for a daily runner although i'd mostly use it for weekend getaways (500km there and back). something reliable and cheap. can i trust a polo to keep going? what are the running costs? mpg?
any other info appreciated! thanks!
Edited by thpriest
  • Replies 20
  • Views 1.4k
GT is 75 bhp
NZ is 55 bhp
hi. i believe here in spain there are 2 versions of the gt. one is the 55bhp engine with a gt trim and another is a 'real' gt with a 75bhp engine. i'm looking for help on how to tell which engine is which. visual clues for example
Look to see if it has multi-point injection?
hi, matt. what does a multi-point injection look like when compared to the other engine? does anyone have any photos of both?
Put a photo of your engine up mate someone will tell you
Matt
Matt
i don't have one yet!
That means nothing if the 55bhp one uses the nz engine
Easiest way would be to look on the log book, the engine number should have 3f in it if its the 75bhp version
thanks. if there is no log book is there anything else i should check?
Most NZs didnt have a Rev counter iirc, So check if the car has a rev counter then should be GT, I think I'm right :p Someone argue against me or back me up!
Edited by POvwLO
I have an NZ with the original rev counter matey
You have a genesis, thats why it has a rev counter, nout to do with the engine.
engine code should be on the V5 (or whatever it is over there) registration document. Providing its not had a swap.
But as its a GT it would have a rev counter either way as that's part of the GT trim
I just thought, Obviously i was wrong....
The dizzy will have the flying saucer/vacuum advance attachment on if it's an NZ 55bhp engine.
I dont't think the MK2's was ever fitted with a fuel injected engine unless it's a G40 or if its been converted.
As for the MK3, as mentioned before if its a GT the engine code is 3F. If thats the code then it'll be the 75BHP engine.
thanks for the replies. what is a dizzy? (i'm a noob and i don't know much of the terminology)
other than the dizzy and log book, how else can i identify a 75bhp engine? does anyone have photos?
what are the gts like for mpg and reliability?
cheers again!
In Europe GT was just a trim level. You could get it on any engine of car
In Europe Mk2's were fitted with Fuel injection.
My Spanish Mk2 GT has an NZ engine.
The Engine code should be printed on the sticker in the boot of the car.
thanks mark. are you saying that all GTs in spain are fitted with a NZ 55bhp engine? i've seen ones that say they have 86bhp. is that a different engine?
any thoughts on reliability and mpg would be appreciated!
The mk2/3 GTs could be fitted with the AAV engine as well (1.3 SPI) fortunately this looks nothing like the 3F engine and so is an easy spot, but as said, the NZ giveaway is the the size of distributor and number of pins on the ignition coil.
In addition there is a mk2 carb GT with 75bhp, but this engine is totally different again, it has a different cylinder head with an 8-bolt rocker cover.
