spaceframing front end
right basically i want to rip the front end off my polo and spaceframe it mounting it all off my internal rollcage that will be fully welded in.
the problem is i dont want to end up having the car Q plated.
I know minis have it done alot so they can have fibreglass front ends but how do they get around the Q plate situation which i know they do.
is it because the front end is so little of the actual chassis that it doesnt matter as long as its structually strong.
reason for doing this is i want a stronger front end with the chassis rails being higher to allow me go go lower with raised custom topmounts and i will be raising the engine as much as possible to and it will all be done properly.
any ideas/ suggestions
i have looked into it with the sva tests etc but they dont seem to give alot of help or information
let me know what you guys think and yes i will be doing this no matter what i just want to avoid getting Q plated as i like my A reg
Peter
  • Replies 16
  • Views 1.4k
interesting idea. getting rid of those cheese chassis legs.
being able to go low wthout anything twatting things it shouldnt
And also, ability to fit pretty much whatever engine you want?
hell of a lot of work though?
Could be done in a day imo.
Alot of mk2 golfs are getting framed at the moment, there must be a way of avoiding the dreaded Q.
On another note, spotted a Q plated Chevvy Truck today, should it just be on day of UK registration plates?
Edited by mattpolo5491
well i now have a 12 tonne hydraulic tube bender and can get 38mm cds tubing at around £5 a meter so shouldnt be too hard just have to get it right and il do all the other bits at work machining wise.
and sticking to my afh engine but turboed running the syncro 4wd gbox which i got to fit to the afh block tonight
Edited by StinkyPete
That first one makes sense but don't know what I would score as engine and transmission are changed, no rear axle suspension is half polo suspension, chassis is original except for te front being space framed so wouldnt know whether I would score like 9 points or just 2 lol
And the 2nd link I can't view properly on my phone ATM
Heres the 2nd link for you
Registering a radically altered vehicle
Registration of radically altered vehicles includes vehicles, which are altered from their original specification, but are not kit conversions. Find out what you need to register your vehicle and how you can keep the original registration number.
Getting a vehicle registration number
When issuing a registration number for a radically altered vehicle the Driver and Vehicle licensing Agency (DVLA) use a points system.
To keep the original registration number your vehicle must have eight or more points. This must include the original or new and unmodified chassis, monocoque bodyshell or frame.
Your vehicle will need Individual Vehicle Approval (IVA), Single Vehicle Approval (SVA) or Motorcycle Single Vehicle Approval (MSVA) if:
-it has less than eight points
-it has a second hand or altered chassis, monocoque bodyshell or frame
-there is evidence that two vehicles have been welded together to form one (eg ‘cut and shut’)
If your vehicle passes you will be able to register your vehicle and will be given a ‘Q’ registration number.
What points are given to what parts
Points are only given to the original major components used and are shown in the table below.
Part Points
Chassis or monocoque bodyshell (body and chassis as one unit) (original or new*) - 5 points
Suspension (front and back) - 2 points
Axles (both) - 2 points
Transmission - 2 points
Steering assembly - 2 points
Engine - 1 points
*Direct replacement from the manufacturers
Where there is evidence that two vehicles have been welded together to form one (eg ‘cut and shut’) a ‘Q’ mark will be allocated. IVA, SVA or MSVA will be required.
Any major component used cannot be taken from a vehicle issued with a Certificate of Destruction.
Vehicle Identification Number and 'Q' registration numbers
A Vehicle Identification Number (VIN) and a registration mark are legal requirement for all vehicles used on the public highway. Find out more about the VIN and registration marks and how to get replacements.
Edited by runforrestrun
Looks like it needs a SVA I think. :(
no it doesnt :ninja:
I've been discussing this with one of my good pals. I vote just do it and worry later.
Could be epic.
i think the reason you can do it on the minis, is that the engine is mounted to the front subframe, so essentially the bodywork isn't structural, whereas on the polo it is.
oh well I'm still doing it and if i get a q plate then i end up getting one anyone know what it means though really il have a look now and see.
Reading into this more today and tbh a lot of the 20vt 6n's on here should be Q plated really too from all the modification to fit the engine
very true! still that will be their look-out if they get pulled by a random vosa roadside inspection. i suspect a lot of the car based pick-ups that are cropping up at vw shows now fall into the same boat too. One thing I'm not sure about is the ruling on cars that were modified before these new rules came in
I've done alot of reseach into all this... yes the 20vt 6n's on here look like they should be Q-plated. But! a big but! when you send of the evidence of the modifications (pictures, write ups, etc) its up to them wether the car is sufficient or not. A mate of mine is an Engineer so can sign of my car and say it safe, if it is! He says if you provide enough evidence and the quality of all the work and it goes through an MOT then VOSA will be A-Okay with it.
So i shouldnt worry about Q-Plates mate, find yourself someone who can assess it and has the papers to prove it (Not some dodgy back street garage), stick it through an MOT and your golden.
That still wouldn't count Matt it's to do with how much of the car has been changed engineers report or not and as an engineer I can sign stuff off myself tbh but it wouldnt count on this occasion that's only for separate big mods but as I will be having so many the only original thing untouched would be my steering lol everything else will have been modified but I will stick it through an mot when it's done as see what they say I could try make it look oem
