changing windows in a mk2
hi guys whats the easiest way of getting the windows out of my mk2 and refitting WITHOUT breaking them?
also will it matter that they have a random registration number on them?
  • Replies 8
  • Views 1.2k
reg dont matter, could always scrape it off? not sure how mk2 windows are fitted so cant comment on removal method
You refitting your windows or fitting new ones?
I've got a black mk2 with the green tinted windows, which i will be driving.
i want to fit the clear windows from my silver mk2 as they look better and the green ones retain too much heat in summer!
harris, i could always just swap the plates and vin number too haha :p
So the silver one is for parts? If so
Then just smash the green windscreen to get the rubber out in tact, then use the old string in rubber trick to replace ;)
weird, green ones In my 10 years of polos are much much cooler inside. Which stands to reason as its darker - otherwise they'd make tinted green houses!
I heard the green ones retain heat? was boiling in the summer lol, either way, i do prefer the look of the clear glass just makes the car look cleaner imo
nope the green tinted ones stay cooler. the interior trim doesnt fade as much either.
Ooooo haha woops!! Thanks for that! Saves me rippin the windows out! Still need to swap the front thougg
