Wolfburg Door Pins
this is so stupid :lol: i ordered replacement door pins because one of mine had been broken by the previous owner. but i cant fit these bloody door pins, they dont want to go into the hole where the old one went, and when i wedged one in i cant screw it on and its stuck, ill have to pull it out with pliers :lol: am i missing something here? they're door pins, never knew they could be so hard to fit, cannot believe I'm writing this
  • Views 804
I've got the same ones, for some reason they're a wider diameter than standard door pins so don't fit through the hole in the doorcard. Only thing I can think of is drilling out the hole on the rubber to get them to drop in.
wish i had googled this before i spent money on them..
thing is i got it in, it just wont screw actually on!
done it, if you remove the rubber surrounding the door pin youll find that the hole is actually more than wide enough its just the rubber that restricts it :)
