Black/Polished Four Spoke Revolutions
4x100 13x6 genuine Revolution 4 spokes in black with polished dish, two have 165/55/13 nankangs fitted (£25-30 each new) but should be changed ideally due to camber wear (might be legal though) can also supply or fit a set of used 165/65/13 tyres for £20 more, id also recommend a stud conversion so the special revolution wheel nuts can be used which you can buy off of ebay, or you can use extended bolts like i did for 5 months but apparently this may be wrong
fronts needed spacing to clear mk2f vw1 calipers not sure if this is the same on mk2's though and i doubt they would fit over vw2's, i used 10mm up front but you might be able to get away with 5mm or 8mm
and pics of them fitted to my coupe with 10mm front spacers and 15mm rear spacers but it think they would look good on a breadvan with the 5 or 8mm spacers on the front and maybe a 5mm on the rear to fit in those awkward arches (not actually fitted them to one to find out though)
Price is £150 o.n.o. collected from Dronfield near Sheffield, a courier can be arranged but will cost an additional £30
Edited by JordonVW
  • Views 420
bump!
may consider swaps also
Edited by JordonVW
Ill give u 100 and ill pick up?
had an offer of more than that collected already sorry, i will include a tub of meguirs metal polish also and microfibre in the sale to make them shiny ;)
Whats the offer you had?
£140 and they are going to be collected tonight, ill let you know if it falls through
SOLD
Edited by JordonVW
