yellow lights
will yellow tinted headlights go through an mot ?
  • Replies 19
  • Views 1.7k
I believe yes as your lights have to be either White or Yellow.
No, new mot laws say that your not aloud to have any tints on any lights
+1
+2
Nothing on the lens can tint or change the output colour of the bulb.
But nowhere does it state you can't have bulbs that produce yellow light.
The vehicle lighting regs state the headlights may have white or yellow output but must be a pair ie not one white & the other yellow
not allowed tinted lights, but you are allowed yellow bulbs
Yep^^^
Mine are clear lamp and clear bulb but yellow light is produced.
Yes but the new MOT rules state you can't have anything on the lenses to alter the beam colour or brightness.
which makes lamin-x and fly eyes films a no go area for your headlamps
Yep^^^
Here are the new rules from the VOSA testing manual
Section 1.7 5b White or Yellow
Section 1.7 5a reasons for rejection would be down to the testers view as to wether the light output is below "that required to illuminate the road ahead"
Section 1.1 3d reasons for rejection would be down to the testers view as to wether the light output is "not visable from a reasonable distance"
spot on cheers guys looks like ill be taking them off for the mot :(
It doesnt say anywhere in those rules that tinted lights or fly eyes arent allowed. It says it will fail if the product is effecting the light colour and effecting the visibility of the light from a reasonable distance.
Correct, it will come down to the individual testers interpretation of those statements
Those pages I posted before are from the VOSA 2012 handbook for MOT testers. The wording gives the individual tester some room to use their judement, as there is'nt a minimum light level for the headlights or a set distance from which the rear lights etc should be visable from, so unless you have totally blacked out your lights, I doubt they will fail? or have a set of non tinted lenses in the car, so if the tester does'nt like the tints just ask of you can fit the alternative lenses and then refit the others when it passes.
Hids a no go??
Hids a no go??
Only if you have an automatic self levelling headlights and headlight washer systems fitted if not a fail!
Where does everyone get there yellow bulbs?
Only pair i found and brought were bloody orange when fitted.
Nice one cheers, what sidelights do you run with those?
I'm running standard (non coloured ) bulbs (h/light & sides)
