Mk3 Saloon boot lock broke
The boot on my Mk3 Saloon is locked shut. The key turns in the lock barrel but it doesn't activate the lock to unlock the boot. Obviously this is a real problem on a Saloon as you can't get in to the boot from the cabin. I need to hear from anybody who has some experiance of fixing this problem. Please don't post here for all the world to see how to break into a polo boot but if you have some use full experiance or info to share please PM me.
Thanks,
Andy.
  • Views 960
a tough one that! my first port of call would be to see if you can access the pull rod from through the parcel shelf- there are a few holes in it which you may be able to reach it through(eventually) a couple of options are to try and remove the lock (using a grinder) and removing one of the rear lights to gain access to the rear of the boot panel(you will need a new light however)
remove the rear back seat squab (pull up sharply) and then there are a few holes and gaps round the panel. reach through or use a long nose pliers or screw driver and flip the pull rod up and it will release. can be done through the parcel shelf as well but it has the seat belt brackets etc through it and the speeker holes are quite high up but they are larger so you can get your arm in.
when you get it open would WD 40 it like a mofo then clean and activte it by hand a few times and copper grease it before you shut it again.
I finally got in to the boot by smashing one of the light clusters and unscrewing the lock from boot lid. The rod had completely dropped of due to some part of the lock barrel assembly having broken. I did remove the seat squab to have a look first hough. Thanks for the tips.
i was hoping you wouldn't have to do my suggestion - but at least you got it sorted:-)
