1983 Polo classic relay
Where are the relays on one of these? I've checked where they where on my breadvan (above the fuse box) but they aren't there, also where is the fuel filter on the earlier mk2 engines?
  • Views 793
Depends which relay you're after, there's two above the glovebox (easiest to unscrew the glovebox to get to them). The fuel filter will be an inline, normally in the engine bay before the fuel pump. Just trace the hose back and it'll be hiding somewhere. The pump is on the back of the head, right hand side on early cars, left hand side on later cars.
Thanks, hopefully find them, think relay might need replaced as i can hear a buzzing noise from it at times
