Mk2/Coupe s bits
Hi all, I'm after a couple of bits for my coupe s, need some clocks, would prefer the rev counter ones but might be willing to take a set of standard ones if they're cheap.
Also I'm in need of the rear part of the headlight switch, not sure exactly what it's called but it's the part with the prongs that the switch pushes on to. Can be from any mk2.
Pm me or text/ring 07949159919 if you've got either. Cheers
  • Views 292
Also, the switch part I'm after, it can just be cut from the loom. I'm gonna solder it on to the GT loom in my car so as long as there's a few cm of wire I don't need the whole length of it.
