mk2f sill covers
Alrite guys just bought a set off sill trims for the polo just wondered which is the best way to attach these??
I've read that possibly there could be painted paper covering the holes in the sills to use?
cheers luke
  • Views 908
They rivet on into holes that already in the sill. Painted paper circles can be covering them on the low spec models. The trims are the right way round if the front of the trim has the first rivet hole furthest from the end iirc.
Cheers mate :) will these rivets be enough? no extra adhesive or anything?
Mine are riveted with a washer to stop it pulling thru.
The standard holes are for 4mm rivets.
The paper covers should show up through the paint, use the nail end of the rivet to find the hole, the paper isnt exactly dead centre sometimes.
cheers mate appreciate it
