Front door window seal replacement
Hey,
I need to change the outer seal that runs along the bottom of the front door window, I have a replacement but I'm not sure how to remove the old one.
Car is a mk3 coupe, any help appreciated!
Thanks, JJ
  • Views 1.8k
if you mean the quarter light rubber its:
best bet is open the door up.
remove the screw for the metal bar at the top.
remove the door trim - handle, inner mirror cover, winder end screws etc remove the mirror and let it hand witha towel round it or remove it totally for peace of mind.
remove the bottom 10mm bolt for the window bar.
wind the window down as far as possible.
carefully wiggle the bar down into the door ( you may need to cut the plastic sheeting in the middle to do this. do it neatly and as small as possible so you can tape it back up or water does get in and warp your door cards. create dampness).
finally run a screw driver down the top of the rubber to get it to start to seperate as it will have been wedged together since it left the factory and will be very happy there.
then put a hand on either side of the glass and give it a real good tug backward towards back edge of the door ( assistant ot hold the door helps at this point) and it should come outstraight back then up.
if not its really stuck and put a screw driver fat wide blade on the rubber in through where the wing mirror was and try wedge it backwards ( mind your paint) and it will slowly come out.
dont screw driver the bottom edge near your paint as it will mark it as the rubber comes down over the paint.
hope that makes sence easier to show than to explain.
clean it all before fitting the new one and use some water to wiggle it in. would put the seal in some boiling water for a while before fitting so it goes in real easy.
or if its the bottom rubber on the bit where the window does down wind the window down. push the rubber back towards the interior and slowly pull up, it might bend slightly but can be squashed back to shape or if your not reusing it who cares.
Edited by genesisGT
That's great, thanks for that detailed guide! Appreciate your time, will get to work changing it when I het home.
Hey,
Thanks, JJ
Sorry to Hijack this thread a little but, where did you get your replacements?
Sorry couldn't tell you mate as I used the ones off my old door. Changed a door but the new door's seals leaked so used the old seals. I'm sure a VW dealership could get hold of some for you.
