electric window relay 6n1
ok looking for the actindoeual location of the electric window relay, and where i can get a replacement as both front windows dont opperate and the fuse is ok, when the buttons are used there is no tell tail click from any relay
many thanks
chris
  • Replies 16
  • Views 10.9k
Have a look in the rubber boot between the door and the a post. Slide the ruined boot back and have a look for Brocken wires (usually the brown one) failing that then take the door card off and wiggle the wiring on the motor itself (this is after where your connector fit, have a feel), if it's damaged then it needs soldering back.
I don't think there is a relay on the 6n1 as its all in the switch.
HTH
HTH
would the same cable problem effect both doors at the same time?
wiring diagram shows relay "j51" where ever that is, swopped at tested both switches and all seems ok
J51 is probably a relay that feeds many things that are switched with ignition not just windows. If you have a multi meter then you could check for voltage at the switch connector and also measure resistance between the brown wires and the car body. Iirc the live wire is black? There is also a grey wire which is for the lighting.
It's more than likely that it will effect both doors as its cause by friction between the wires when the doors are opened and closed. Its an overlooked fault from vw as the route the cables take is to sharp of an angle. All the polo I have owned and all my friends cars have had this problem.
Is there any sound at all when you press the button? Like a clicking in the doors?
there is no clicking at the doors....and the lights on the switches themselves work fine.....
Have a look at this for the wiring diagram http://www.clubpolo.co.uk/forum/index.php?...p;#entry2292585
Relay 51 is above the main relays under the dash, it only provides power to the windows when the ignition is ON there is also a thermal trip next to it, this does'nt affect the backlighting in the switches
Edited by nige8021
have you any idea what the relay looks like?
A standard relay with four connections on the base
have you any photos or diagrams as to where it is? once i pull the fuses out the way there is a line of relays behind,
cheers mater if you can help
What year is the car?
1998, s plater mate
1998, s plater mate
There's no picture showing the actual location but here's the description from the manual
J51 - Electric window relay, next to relay plate
On the pre Sept 97 cars the relay is clipped onto the righthand end or on top of the main relays along with the thermal resetable trip/fuse. On yours there is'nt room in the relay carrier so it will clipped close by
1998, s plater mate
pulled the relay next to the thermal fuse......stops the rear wash wiper!!!! hmmmm i'm lost lol
1998, s plater mate
1998, s plater mate
i just have a single row of relays behind the fuses :(
1998, s plater mate
Red are the relays, Blue are the connectors
