Changing steering wheel on a 6n
Hi there,
I have decided to give my 6n a serious facelift, both inside and outside (steering wheel, gear knobs, internal lights/dash color, outside front and tail lights, etc. etc.). I have been looking at a new steering wheel and found a guide which tells you how to change your 6n steering wheel to a 6n2 steering wheel. I will either get a 6n2 or, if possible, a golf mk5 steering wheel. can anybody tell me if it's possible to put on the mk5 steering wheel, or doesn't it fit? Also, will it be possible to have sound controls for my radio on the steering wheel? I suppose i just need to connect the cables from the steering wheel and down to the radio?
Also, when taking off the steering wheel of the 6n, is there any causions that i should do? I have disconnected both the + and - on my batteri and left the ignition on for an hour. I am worried if the airbag will just smash off anyway, can anybody please tell me how to handle this?
A last question would be, is it possible to get door panels for a 6n where the speaker holes have MOUNTS? I had to "customize" my setup in the doors cause my panels is just a whole, there's no brackets on them. Already spoke to VW here in Denmark, they can't help me with that. It's a 98'.
Thanks. :-)
- Chris
Oh, and another question: is it possible to get cruise control on a 6n? I've been searching a lot but could only find something about 6n2. I'm driving about 35000km each year (mostly freeway), so it's nice to have, if possible. :-)
You can retrofit cruise control to anything, almost like a servo to control throttle electronically.
6n is cable throttle so couldn't be done as standard via ECU & extra loom
Hi, thanks for the answer. is it possible for you to explain? Is it just to put on a new cable arm, or do i need more than that?
