Carter - 9N Polo audio build
Here's my audio build for my 9n
This threads mostly for my box build but I haven't got round to that yet but slowly making a start.
Items brought/given:
Items fitted:
Radio Surround in mat black to match the rest of the dash.
Box idea:
Ignore the 6x9's Not going to happen!
Progress pics:
Cage fitted, Fascia fitted, All headunit cables ran, Iphone and Bluetooth mic installed and working.
RCA Cables ran and fitted the remote cable. Hidden under the centre console and carpet. + Amp live :thumbsup:
Massive thanks to bass_hoff for all the help and advise so far!
Any Questions?
Edited by LiamMk6Polo
  • Views 547.7k
Amp live Wiring done today, Took a few pics to show how I done it:
First i started with taking the front windscreen wipers off to get to the scuttle. Once that was removed I had a look at were the bonnet release cable ran (drivers side). The on the passenger side there were two rubber grommets (Were the cable would be for Europe models). With this then noticed there was the exsact same a few inches behind underneath the windscreen. So me and my dad got a long sharp bit of steel cable (Fencing wire) and poked it through both of these grommets and to no surprise there it was under the dash. So we widened the wholes in the grommets and fed the cable through. Took around 3hours as of us not having the right tools and being physically tricky. Saves drilling the bulkhead and is worth the time.
Remove this access panel makes it allot more easier than lying on your back:
Were through!!!
Here is the finished job.
Not connected!
Perfect place for the fuse :D
Under the dash, Now completely hidden
Completely hidden under the side panels under the seat into the boot.
Any questions feel free to ask!
So I got this today:
Any ideas on how to attach it my sub and amp?
Thoughts?
Sub box idea photoshoped
So I got my sound deeding in the post today, so went out and put it in my boot and under seat. I also tapped my cables nice and neatly :D Quite happy with the result.
Here's some picies:
Also blacked my amp (Logo anoyed me)
To: 63f78283.jpg
Liam
I would have mounted my amp into the box. But it looks smart. How hard did you find routing the wires? I have a 9n, but am put off upgrading the ICE due to the hassle of having up the carpet etc.
Edited by prankstar2003
Cheers. I was told not to so I made a mount and stuck it there. Erm the only problem I had witch was the live from the battery but I haven't taken any carpets out and can get all the cables out within 10 mins. :) tucked under trims and through the centre console :) easy job.
