Big 308mm brakes for 86C Polos
Calipers, carriers (with slider bolts), used pads (nearly new) and used 5-stud discs for a 308mm front brake setup to fit 86C Polos. Get some shoulder bolts as per the popular 256mm Vauxhall conversion and these bolt on. Discs will need re-drilling for 4x100mm PCD and checking for fit/clearance if you wanted to use them on the Polo, but I'd buy new ones - used ones only included so you can mock stuff up.
£150ono.
Proof that they fit a Polo strut:
I'm told that some Meriva diesel 288mm discs are 4x100PCD and work with these calipers and carriers too, but I've not tried.
  • Views 223
What are these from Andy, if you don't mind me asking? Are they vauxhall calipers?
i've done the 256 vaux conversion and was tempted to buy the bigger ones off the turbo modle..
But 256 is more than enough so fair to say these will be insano stopping power ;) !!
