Fitting bucket seats
Hello, I'm fitting bucket seats into my mk2f but it's the harnesses I'm having trouble with there 4point but only have 3points for mounting each side what have you done to have 4points
I'm not using original frames so can't use the old seatbelt release point
Sorry it's for the front 4 I'm using 1 front original point per side it's just the centre of the car ones
But cheers for that I'll do that too :)
No the points that surrports waist one on inner sill point per side but it's the other waist side
It would go to the original seat subframe really
I don't have original frames wish I made frames on my old ones no, I've got box section welded across and the seats go ontop, yes I've just looked at the plates is the thread I need 3/8 unf?
There just eyelets I've measured my others only need 2 and the plate, but I've had a look and there isn't alot of room and were I want them there's a step down aswell as being curved
The plate is 4mm I think putting a curve might be a problem
