roof racks
i have been looking for a roof rack for my 6n2 3door but they are expesive but i found that the golf 1 are alot cheaper and easy to find second hand but am nt sure if they will fit dose any body no?
  • Replies 8
  • Views 1.7k
No.
Back in the old days, cars had gutters and universal gutter-mount racks fitted everything. But people didn't buy new racks for their new car, just used their old one.
Clued up to this, as aerodynamics went anal, manufacturers did away with the design and keyed their own pattern of mounts to their new cars.
Good for manufacturing, not so good for direct re-cycling. Such is the business orientated world we live in.
The MK1 Golf rack is probably just a universal one, it'll fit pretty much anything from the 60s and 70s including MK1/2/2F Polos but it won't fit your 6n1/2 roof.
No.
I was looking at the 1s from a mk4 as I no they are the same kind of fitting but just dnt no if they are same size.
No.
Here are some dimensions from the body jigging section of ElsaWin
Polo distance between "B" pilars 1338mm
Golf distance between "B" pilars 1416mm
Polo distance between "C" pilars 1324mm
Golf distance between "C" pilars 1399mm
So the cross beams would need to be adjustable to fit a Polo
No.
So the fittings are the same just would need the bars shorter for the polo?
I've got a retro Fitted roof rack on my 6n2.
If you want i can give you Thule numbers
Edited by Moles Nose
No.
From what I can tell the fittings are the same, would make sense from a parts ordering point for VAG Have you had a look at either the Thule website or Halfords to see if they show the same fitting feet for both cars this would confirm it?
So yes the spacing of the mounting fittings on the bars would need to adjusted inwards to fit the Polo.
The spacing tends to be adjustable for width. It's the key shape for the roof channel design that differs from marque to marque.
Thanks for all the help guys :D
