6N2 GTI Door Panel Removal
Hi,
I have just purchased 4 new speakers for my car and will be replacing the originals sometime next week. Could someone please advise me on removing the rear door panels? I have not found any way of getting these off yet, my car is a 3 door. Thanks.
  • Views 2.6k
Hi,
Removing
– Remove window crank -1- 10.99 ► → Chapter. Removing
– Loosen locking lugs -arrows- for trim -1- and swing trim down.
– Remove bolt -2-.
– Pull window crank -3- off from drive.
– Insert a flat screwdriver into aperture in handle and lever trim -2- out in -direction of arrow-.
– Remove bolts -3- and -4-.
– Use removal pliers -3392- to separate clip connections -arrows- and loosen door trim.
Refitting is the reverse but check the alignment of the winder!!
Installing
Notet The installation position with window closed is a = 45° ± 12°.
t The -arrow- in the figure indicates direction of travel.
– Place window crank onto drive in installation position.
– Secure window crank with bolt and clip trim on.
Yep my mistake just read rear door trim and ignored the 3 door bit :lol:
Here's how to remove the side trim 8-)
Removing
– Remove bench seat and backrest
– Remove bolt -1-.
– Unscrew studs -2-.
– Unscrew pin for backrest lock -3-.
– Loosen side trim in area of side panel clips.
Fantastic advice guys, thank you. I will give it a shot early next week and report back how I get on :)
Cheers again!
