Biggest roof box for mk5 polo
Hi,
Having had a baby and not wanting to get a bigger car, becoming apparent I need a roof box!
Just trying to work out what size.
I have a 2010 polo 5 door
Anyone got any experience with this and what size box did you get?
Looking at the Kamei Delphin 380 which is 158x94x40cm
Just wondering if anything longer would work but the rear aerial is rather limiting!
squelch41
Edited by squelch41
  • Views 908
Do you need the aerial on when the roof box is on? If so, can't you put an aerial base on the roof box lid with a wire around to the underside, and plug it into the base on the roof when it's on..? Or even an amplified wireless aerial on the roof box?
I can't be the first to think of this, they might be available already. If not, the first suggestion would be simple to do.
Not sure that aerial stub would be low enough but that is a good point - could try without but all a bit of a faff! Also would the overlap boot hinge so would limit access. Would prefer to keep aerial on if poss
