Seat collapsed
sitting in the car earlier, heard a click sound like when the seat locks into position but the bottom of the upright section has collapsed and has no support like the passenger seat.
can this be fixed, how do you take the seat apart to have a look.
  • Views 722
You can take the seat apart relatively easily, start by taking it out. Look under the front part of the seats, you will see a runner in the middle and a 10mm nut and bolt through. Remove these and then slide the seat all the way back by hand( don't sit on it) the middle runner will come off its mount and the rear runners will go all the way back. They may be plastic covers on each runner these will need to be pulled off to allow the seat to come off. Take the seat out and if you can it's best to put it on a table or something that puts it at chestish level. Remove the adjuster knobs and the trim piece, you may have to remove the side pocket this is just screwed down. Where the seat puvots there is a metal clip either side of the seat. Remove these with a flat head driver, you can now remove the top part of the seat. If its a heated seat you will have to either remove the pins from the connector or cut the wire and resoldering when finished. To take the covers off there are little metal spikes along the bottom of the top half of the seat, bend these straight with pliers and then unclip the fabric from both sides. Remove the handle part by pulling it ff and there is a screw under a cap at the bottom of the trim. You can then slide the cover up, but if you want to remove it completely you will need to take out the headrest tubes. I usually push and screw driver down from the top, back and front sides are where the clips are but doing this is a little tricky and you may end up breaking it so I would leave them alone. With the fabric raised up you will see a crisscrossed metal wire section, this is the back support and there should be iirc 10 springs (5 either side) an they should all be taught. What's happened with yours is that they have all probably come loose because they have been stretched or the place they where mounted to has stretched. You will need a strong pair of pliers to put them back on, I would do top left then top right then next one done on the left then the right etc. when you put them back on try not to put them where they where before instead try to mount them either inward or next to where it was mounted. Once it's all done and is taught a few squirts of wd40 on the springs will make them not squeak later on. Refit in reverse order and enjoy.
HTH
Edited by dixy
thanks for the reply, i'll try giving it a go in the next couple of days.
do you have pics by any chance.
