6n oil pressure warning light
Yo.
Having issues with my warning light, has been on ever since carb conversion but I put a temp one in for now.
The light flashes and beeps whenever it picks up a rev signal.
Will beep one, then again, then just flash the light.
Have tried:
Revs spliced to clocks
Revs spliced to ecu
Ecu connected
Ecu not connected
Connected oil pressure switch
Replicating having an oil pressure switch
Can't get rid of it, I'd like it tO work properly...
Diagrams show just the Switch to ground, and the other side to whichever pin on the instrument cluster.
It won't work at all with rev feed disconnected. But obviously I want a rev counter.
I don't mind having the other warning light, but then I'm into removing the buzzer and light from my IP.
Any ideas?
  • Replies 26
  • Views 4.6k
When it's connected up, just with ignition on, it beeps, but not connected, it won't beep.
Until you start up, then it will.
ANNOYING
Edited by harris.racing
Dash panel insert for vehicles 1998 >
Connector contact assignment on dash panel insert
→ 32-pin connector T32a, blue
1 - Terminal 15, positive
2 - Warning lamp for turn signal, right
3 - Output signal from electronic speedometer
4 - Vacant
5 - Fuel gauge
6 - Airbag
7 - Terminal 31, sender earth
8 - Coolant temperature gauge
9 - Terminal 31, earth
10 - Oil pressure switch------- T10D/6 near realy station then to pressure switch
11 - Speed signal------- Pin 9 ECU
12 - Warning lamp for alternator, terminal 61
13 - Warning lamp for glow period (only Diesel engine) or warning lamp for catalyst monitor (only certain countries)
14 - Warning lamp for rear fog light
15 - Vacant
16 - Vacant
17 - Warning lamp for main beam, terminal 56a
18 - Warning lamp for turn signal, left
19 - Anti-locking brake system (ABS)
20 - Dash panel insert illumination, terminal 58d
21 - Signal for driver's door open
22 - Coolant shortage indicator
23 - Terminal 30, positive
24 - Terminal 31, earth
25 - Self-diagnosis/K-wire
26 - Parking light right
27 - Parking light left
28 - Input signal to electronic speedometer
29 - Warning lamp for brake system
30 - S-contact
31 - Seat belt warning system (only certain countries)
32 - Warning lamp for side lights (only certain countries) or emissions warning lamp (only USA)
Have you got a diagram of connections onto the warning buzzer?
I think the buzzer is used for headlights and the oil pressure, where I only wan it to beep for headlights
You'll struggle if not impossible to get a diagram of the internal connections :-( I think the buzzzer could also be used in some countries for the seat belt warning, so basically there will be a single output from chip to the buzzer and internally the chip will switch the output on when one or more of the conditions (OP, lights on etc) I'm wondering if it's something that you might be able to enable/dissable via vagcom ???? in Elsawin it tells you how to test the various warnings, have'nt found yet if you can disable anything yet!!
Well there's 4 connections to the buzzer, its defo used for oil buzzer and headlights, I was hoping to just remove the connection for the oil side of things
Ok in that case, would it be possible to temporary put the dissmantled unit back into the car and run the engine, then artificially simulate a low pressure and check which connection to the buzzer has power to it?
see on the diagrams all I can find is "oil warning buzzer" with two connections to it, I can't even find te warning buzzer for the headlights on Elsawin
I've just totally dismantled my speedo unit (newer type) and the two legs at the bottom of the horn are just physical support legs, the top right is the +Ve supply so the left must be a switched earth but I can't follow where it goes to the pcb track goes off in so many directions!!
As you say, in none of the diagrams can I find a mention of headlights on buzzer??? Yet it is listed as the buzzer in the speedo?
Warning buzzer
◆ Oil pressure warning
◆ Lights switched on warning
◆ Seat belt warning (only certain countries)
◆ Speed warning (only certain countries)
So it looks like. suffer with the oil buzzer or have no headlights on warning :-(
Iv just done the same!
Also noticed the other two are just supports,
Ones a ground but the live, do they alter the current to this to change the beep tone?
It's a strange one, definitely can't find another buzzer on the board anywhere! And only two contacts.
I can remove the SMD for warning light.
Do you have to have the headlamp warning?
Look like this? :p
The +Ve supply goes to a 20K ohm resistor, but the other one goes off through the pcb into so many directions.
The smd led for LOP goes down through a 68 ohm resistor then onto a chip
Might just have no lights on warning?
It's only to remind you to switch them off to avoid flat batt? Isn't a requirement for MOT is it?
Not any sort of requirement, just a nice convience, if you still wanted the h/lights on buzzer, get one from a 96~97 model wher it's a separate relay in the fusebox??
Did your LCD units come out OK?
In the bottom pic, the chip just to the right of centre controls the LED's, the input for the LOP is pin 16 tried following that back and it goes to the main chip under the buzzer, so the switching is all done in that chip and that will control the buzzer as well
Ciao
if you can keep the headlight warning then i suggest you do. I've been driving my mk2 for over a year now and i still forgot to turn them off twice today. lucky i bought a new battery last week!
All good except the clock doesn't work and only half the trip display works, will clean contacts.
& will address light buzzer :)
Yeah, just desoldered the SMD.
I still have high beam warning, have just lost the buzzer when you open door and lights are on :)
Just get a buzzer relay from an earlier car if you want the lights on buzzer :-)
Can you read the part number of the main chip thats under the buzzer, it's not that clear on your posting?
Tbh it never really bothered me lol. It's so nice not to have a light flashing in my face haha! May put a buzzer on my other oil light incase though!
Erm unless I can see on pic, no, as its back in car!
Will zoom in on a pic, maybe able to as phones got a decent camera.
Thanks for all your help though mate, you really are a star!
Also got my Elsawin back! Just not very good at it haha
May be able to make it out, will grab a pen and note what I think in a minute
On my Manta & Escort rally cars I fitted a second LOP switch that operated @ 25~30psi and that was wired to a big warning light so it gave a bit earlier warning and you could kill the engine before any real damage was done as by the time the normal one operates @ 4psi it's usually to late :lol:
