flap motor reset
Is there anyone in the Staffordshire area with Vagcom able to reset my flap motor? I have removed and cleaned it internally but i hear it needs to be reset. I have cleared the codes with my code reader but still the same.
  • Replies 10
Where abouts in staffs are you? I've got full vcds here...
in Tamworth. A bit away from you
Sorry for the dumb ass question but wtf does the flap motor do?
Flap motor controls the heating flaps behind the dash. Well known probs on these cars. Makes you have heating problems.
flaps.... Haha ..
sounds like a female pleasure implement
:-o
dnt get me started on this stupidly annoying part !
one day randomly i hear a clicking noise from behind the dash aafter weeks of playing the stereo loud and ignoring it i decided to find out what it was.... looked through forums on what it could be, lukily car was due a service so tuk it to VW and they narrowed down what it was...
the stupidly annoying flap motor..... which to replace they wanted to charge 60 quid + 6 hours labour = nearly 700 quid !
my car still meks the stupid ticking noise and i had to visit a guy breaking another gti and smash the dashboard up to get the part out...
the part lives in my draw and i still have the ticking noise....
you think VAGCOM could sort it?
does this make your air con not function properly eg. not ice cold, annoying groaning clicking noises?
If you ever end up over Coventry way I could do it for you
you can hear a clicking noise every now and then. usually just after turning the key. I've had it out and cleaned the resistor thingy. Yeah, cant seem to get much difference when ac is on. In the summer when its hot if i get it set to coldest position could i just remove the wiring plug from the motor so it stays in the coldest position? will the ac work better? I have a VAG scanner that can remove hvac codes but it dont seem to remove the fault code. Will getting a new motor fix the problem. Do i have to reset the new one once fitted?
Can get a new motor for £40.
Edited by PoloGuy81
