Couple of questions about my 2001 Gti.
Couple of questions on the Gti.
1. Does it have some sort of traction control as standard. I noticed in the brochure it says EDL, Electronic Differential Lock?
2. The Climatronic aircon system I presume should be able to go cold, yes? If it does I need to get mine re-gassed.
3. What's the general consensus of opinion on stock suspension on the GTi versus having coilovers? I'm seriously considering putting the stock stuff back on.
4. I've heard talk around that the gearbox on this GTi was a bit shitty for use on this car because it's not really strong enough. True?
!m!
  • Views 602
EDL acts like a Limited slip diff allowing traction to be equal across both wheels (I think)
climatronic should blow cold and hot.
couldn't comment on the suspension.
Gearboxes are the weak point, but its how you drive it that counts. I had to replace my gearbox when I bought my 16v which has 25hp less!
EDL is theoretically hard on gearboxes, as it's a traction control method that actually has nothing to do with the gearbox. The 6n2 GTi's 085 series gearbox was not originally designed to cope with it, and the model's reputation for breaking gearboxes is likely related.
How it works: It's part of the braking system; The front brake is applied on whichever wheel is spinning, causing natural transfer of the load to the other wheel via the diff. As you can imagine, this increases load on the gearbox when the engine is giving it beans and the brake is giving it resistance! But by keeping a rogue wheel from spinning up it increases traction.
For daily road use, factory suspension is obviously far more comfortable than copies of a race design. The roads are not like glass-smooth race tracks and so the car requires suspension designed for roads to work properly. But it's 'scene' to bounce around all over the shop with your CD player jumping.
Air-con is often referenced to cold air, but i don't know much about that. I usually find opening the window helps (but for all of three days a year).
