6n2
Hello everyone I recently bought a polo 6n2 and it came with fk angel eyes, I was thinking of getting some gti lights as they are brighter, but in all fairness is there any difference between the two as they are apparently both projectors? Other than the obvious fact of having halo rings? Cheers :)
  • Replies 20
  • Views 2.5k
The gti's use xenon bulbs so should be brighter unless your angels have a HID kit fitted
so basically i can just put xenon bulbs in my angel eyes and they will be basically the same as the gti lights? is there any difference in looks? i dont want to spend like 80 quid on a set of lights if they are the same lol :L cheers
I've put a HID kit in my angel eyes, i think they look better IMO and they will be just as bright as OEM depending on how far you go with the colour temperature.
Edited by springcleaning
Won't that melt the plastic on the casing Becuase of the tempeeture? Are the LED headlights illegal?
sorry when i mean temperature, its the colour, so for example 4.3-5000k is bright white light, I've got 6000k which is a nice blue. I've heard HID's can melt the inside, but i haven't had any problems :).
HID's all the way!! I've got them in my 6n at 6k aswell slight blue tint and they shine around 3-4 times further then normal lights
Yeah that's what I heard that they will belt the plastic on the headlight unit on angel eyes coz there not glass unlike most standard ones or something lol, I know what you mean buddy aha :) my cousin has them on a civic and there lush :) so bright but his are like 4000k and they are stupidly White :L are your lights the projectors? And have you hooked them up to your halo rings?
I did have a set in my old angel eyes (projectors) they never melted but only ran them for 6months as thy failed MOT on being LHD light units (had wondered why light output was odd) so fitted my original units depo'ed them and fitted HID's. Did wire them to the ring as the ones I had were built in without being able to change the bulbs
Ooh right sounds alryt then, what strength did you have in yours then buddy? Did it look nice when it was all wired up :) ?
I put 6000k in both, wouldn't go any higher as the light goes more blue (more reason for police to pull you) looked nice but since I've put my originals back in and HID them I think they look a lot better IMO
Ah right sounds good buddy :) might buy a set off eBay after my MOT this month :) you think the original lights look better wig HID than the Angels? And just being a noob but what does OEM stand for lol? Original equipment manufacture or something else?
matto1 if you have the FK/depo angel eyes they have a switch where you can change them from LHD-RHD and vica versa :). Also how did you make your halo rings xenon? i thought you had to replace the LEDs in there? Ash, you've answered your own question :) x
That's what I want to know aswell lool, few people are talking about how they HID there angel halo's lool, thanks buddy thought it might of ment that, can you get the black inserts for the fk angel lights or do you have to buy the black ones? Is there anyway of spraying it at all?
I will have a little dig around and try if i can find anything on making the halo rings xenon, I've meaning to do it for a while. I take it you have some white angel eyes then? you can either spray the inserts yourself, or buy some new ones up to you really! :)
I didn't know an easy way to I went about a long process of modifying the unit fitting a set of HID's in a custom made glass tube that extended in and went in place of the halos inside. Took me ages to get it right! And it's still not great, looking at getting another set to perfect it.
I didn't know that but I brought them off someone on here who claimed he didn't know they were LHD but I think they were cheapo ones and didn't notice a switch :?
Well i would rather spray them if that's cheaper aha don't want to spend like 120 quid on a new set lol :L how do you get them apart to spray it all :)
Front what i have been reading over on uk-mkivs, you put your headlights in the oven at 80degrees for about 4-6 mins always checking it until you can pull it apart. Also regarding changing the colour of the halo rings, the best method i have found is replacing the LEDs with CCFLs, you'll need 125mm for the outside ring and 100mm for the inside. that was for a MKiv golf, i dont know whether our halo rings are exactly the same size?
I'm not sure if they are mate to be honest.
When i depo'ed mine i used a heat gun that i got from B&Q for £20 went round slow so the glue softens then gently prise the glass off (not a fan of the oven way) make sure you get all the glue off the lens and the unit ready for refitting.
I cant stress enough the importance of using heat resistant paint when depoing them! I prefer using a paint brush aswell as opposed to spray as i find it easier, also make sure you do not paint the reflective part whatsoever as this will affect the light output. Then i just used clear bathroom sealant to re-seal and have never had a problem since.
Heres some pics of when i did my current lights so you get the idea, please excuse the size of them i cannot resize :thumbsup:
Is that a 6n2? Looks like some good advice lads will Definatly help me out when I'm doing the work :) will it matter about painting the reflexive bit I'd you got angel eyes a's there projectors :) probably a stupid question lol just don't want to mess it up lol :)
Nah it's a 6n but its jus to give you a general idea, as for angel eyes just look at which lights will use the reflective part and which don't, ie dip beam uses the projector so paint around that etc
