Breaking 1.0 4spd Mk2 Polo Early Engine
Except the radiator everything in the pic is available.
  • Replies 41
  • Views 553
Could do witht the oil spray bar and plastic fittings from the head. Do you know what cam this has?
Oil spray bar? Plastic fittings? I can only guess the cam is whatever was standard in a 1050cc engine. Not my most educated reply i know!
If you take the rocker cover of, you'll see there is a tube that runs along the top/rear. It has 3 small plastic fittings, one at each end and one in the middle.
Do you know the engine code?
Ah OK, never taken a rocker of this type. 1043cc GL engine code.
Cool, thanks. Seems its a tame cam, so I'll stick with the one I have. If you have a chance to get the rocker off, can i have the tube?
GL has the poverty spec cam.
I'm Interested in the head for a spare.
Yeah, so I've since found.
OK, If Gaz is fine with head without the tube? everyone can be happy.
yeah i have a few of those spare :)
Okey dokey. Price delivered?
Will find out how much it is posted in the week, the price wont be much as I'm not really trying to make any money on something i was going to bin.
I'm in no rush so if you want to hang onto it til a show that's fine with me. I'll be at stanford hall in a few weeks
Sure thing Gaz. I'm not going the Stanford, E38 is a definite.
I'm in no massive rush, although I wont be at E38
I'll have both bits of the cambelt cover. No rush.
Yeti: Only had the top bit of the cambelt cover, didn't have two bits?
Prankstar: Got the thing today, £4 posted?
Gaz: Let me know what other shows your doing or mates of yours and we can sort something.
PM me paypal details boss
Anyone else? What doesn't get spoken for gets binned at the end of the month.
ignition loom, coil and dizzy? can you check the part number of the dizzy for me please mate?
interested in just the inlet manifold. no carb or anything.
loom not available, coil £5, dizzy + vacuum advance £10 + P+P (Will try and check number this weekend)
£10 + P+P
Edited by kerrly
How much for carb?
What condition is the radiator in?
