Heater issues
Hint heater hot/cold dial turns from the cold blue dot to 3/4 the way round to hot, is this a common problem or is something broken?
And also the position able vents on the dash only blow cold not hot, but yet everything else is normal?
Would be every helpfull If you cold guide me as to what's wrong or I yours does it to?
Reece
  • Views 737
I'm assuming from your description you've got a mk3? If so the big vents only blow cold air, the little ones above these are for warm, so when you've got the heater on keep em closed.
The dial not turning could be a problem with the cable that runs from the controls to the matrix.
Take off the weather shield from the scuttle tray and on the passenger side of the heater matrix there should be a lever that's controlled by the dial you're turning via a cable. Make sure this can move to both limits and check the cable can move freely and that nothing's fouling anything.
Edited by deanopolo
sorry forgot to put its a mk3, ill have a look in a minute. The cold air things a bit gay but at least the floor heater is the bees knees.
thanks
