MK3 Wing Removal?
Just trying to remove my passenger wing and i have removed all the 10mm bolts i can see and the 2 8mm's from the arch liner and the aerial but it just doesnt seem to be coming off asif its still held on around the door side
  • Views 665
theres 3 bolts under all the underseal inside the arch when it meets the door and one outside underneath on the sill and the wee philips screw into the front panel under the bumper next to the front 10mm bolt
if you get the arch liner out then feel for them and then scrap the underseal off ttill you can get a socket on them ones about 15cm from the bottom, 1 in the middle and one about 10 cm from the top (its the hardest one).
then its a pull forward up and out joband get an assistant to slide a big flat screw driver up the back to break the underseal. its not fun would di it with the car door open or off. so you dont risk you paint.
Thanks mate, there was alot of under seal but i got threw it and got it off :thumbsup:
