9n bumper strips
Hey guys. How do you remove bump strips from the front and rear bumpers and doors? Please help
  • Views 5.4k
Front= take off number plate and simply start prying off on one end working your way to the other end, the moulding is clipped in
Sides= simply open the door and pry off on the ends (closest to door catch) and when you can get a hand under just pull off, these mouldings are stuck on with adhesive tape
Rear= remove number plate lights and then remove in same way as front, also this moulding is clipped in
thanks mate
do you intend to remove for a purpose i.e the smooth look, or are you having them colourcoded? if your having them colourcoded then i would highly recomend buying new side mouldings as they loose shape when removed and are a pain to re apply and never look right, for the cost of new ones its daft not to
Ahh right cheers pal. Was going to colour code them but I may leave it till I've got the time to smooth them. How much are new strips?
its been a while since i orderd some in but i believe the doors are around £30each and the rear quarters are around £20 each (based on a 3dr)ring your local vw dealer for an exact price, belive me its definately worth buying new otherwise when there reapplyed they look very ripply and uneven and give the optical effect that your cars full of dints, i have seen people who have had them colourcoded on the car but theres so much product that has to be applyed to get the smooth effect (get rid of the plastic dimpled texture) that they look tacky and cheap, the bumper strips are easy enough to do tho
So the bumper strips I can use again? And mines a 5door so we talking 20 a door? Ish
