grand's polo pimp wagon!
after seeling vr6, i will be picking up this  a polo estate tdi completely standard from just outside wales..
only had it one day and debadge has commenced.....
  • Replies 11
  • Views 1.6k
if you don't have funds to buy black badge do it yourself!
indicators!
also managed to wire in the sub! even with the sh!tty stereo that is in there!
also sorted the clutch problem! someone has tightened the cable to full! so only had 2cm of free space before the bite
here what i been up to recently, had clutch done and i replaced the f**ked wheel hub.
did some work on a mates polo estate.
Nice to see another couple of wagons on here. Think they are starting to get popular recently.
Cheers bro, can't get better than a wagon cool and practical, ;)
Sweet! I fancy one haha
Try an AKL or AFT engined one. Mines knocking on 120bhp with a few cheapy mods!
really from 1.6 nice, mines 1.9tdi which has a bit of power just not to sure what else i can do with a diesel engine..
Front mount, bigger injectors, hidden exhaust -remap :)
Power Gainssss
Power Gainssss
As above - remap = circa 130 (assuming its a 110 to begin with) on its own
If not;-
Full service (oil change, new filters and maybe change the coolant as well - i did all that to mine plus new spark plugs)
.215 injectors from a 110 version
bigger front intercooler
remap
upgrade the exhaust
should see more than mine without much trouble
If you want to go mad with it - try tdiclub.com
Oh, and mines an 8V so its pretty good for what its got.
Just dont expect it to go silly low - the TDI is a big block so lower it more than 30mm on stock wheel and you will smash the sump apart. Mine catches the front splitter as it is and its dropped by 30mm on the stock 14" alloys.
cheers yeah it is the 110 version.
already planned on a intercooler,
other things didn't think of, but shall look into them
only one way to find out with lows is get the coil overs on, but see how it goes :\ ha.
