TT pedals
Seen these on ebay today and I'm very tempted by them are they tend to go for about £35 for a second hand set normally, anyway they state for LHD models only, I asked the seller but got a totally naff reply as i presume his english isnt the best...
Anyone know what the difference is between LHD & RHD models that i dont know about? They look just like a RHD set though!
cheers if i anyone can help?!
  • Views 747
presume its the pedal covers you mean.
dont buy the set as it wont fit. for a mk3 90 - 94 polo
you need 2 brake pedal one (dont have the wee rubber bung to go through the pedal on the back)
and a LHD accelerator pedal.
the RHD (chamfered corners) and LHD (square corners) accelerator is different shape and different curvatures.
you still need to bash the LHD one straight as it has a slight curve.
hope that makes sence. you also get R32 ones to which are quite nice.
this has a pic of the wee rubber bit I'm on about...
http://uk-mkivs.net/forums/t/369367.aspx
Edited by genesisGT
I took the accelerator pedal off the car and ground it and filed it a bit until the TT cover fitted.
