iPhone on the mk4 dashboard - how ?
Hello,
I am wondering how to use my iPhone 4S in both Polos.
Both carstereos have got a connection via bluetooth and i prefer a mount on the airvents above the radios, not mounted on the windscreen.
Could you post some pictures how you have mounted your iPhones or other smartphones?
Man i don't want to mount a holder with screws of similar, i want a solution like plug & play without leaving marks or wholes on the dashboard....
cheers
Christian
  • Replies 13
  • Views 3.9k
haven't got any pics, but for my ipod i put a strip of velcro on my ipod and a strip on the dash?
was quite usefull and held really well!
Yeah that's what i was thinking about too.
On the mk4 dashboard a stripe above the left airvent, so it's right in my sight and nice under the windscreen for gps.
I think that's what i will do, i will try to get some clear/invisible one cos my dashboard is wooden :-(
Thx m8.
cheers
Christian
A rubber cup shaped holder, in the VW cup holder and iPhone sits nicely. Will upload pic when I get in the car to leave work :)
Edited by bjblyth
Velcro.
It's cheap, your phone gets a brazillian, and you can mount it anywhere.
i use one of these Link, they slot into the vent so I had mine on the drivers side by the window.
On a mk4?
i have got two of them from ebay, but they won't realy fit on the airvent above the stereo.
not very good solution in my eyes. i realy try the first solution.
cheers
christian
I've tried many, none really work so I just connect it to the HU and shove it in the under steering wheel glove box.
Although I did have one screwed into the heater vent with 2 L shaped brackets. these screwed into the plastic inside the vent and the vent itself fit over it then i bolted the phone holder to it. The holder was one of them universal jobbies that slide to any size. It didn't last long as the springs broke so it went out the window.
Try this it could work with a little bit of hack saw fun.
Or One of these
yeah mk4 i didn't put it above the stereo cos they get in the way but the vent closest to the drivers side window is perfect, they slot in fine, maybe you had a bad one...
Hey there, this is my solution, the case of my iPhone is realy thin and always on my iPhone. So i just took some velcro and you can see what i did.
For under the vent i will make some kind of 10mm spacer in case i have a long journey like to the poloshow, otherwise the charger's connector would push some buttons on my carstereo.
Yeah i am a right hander, so that's the perfect place in my LHD, if i would have a RHD Polo i think i would to the same and place it also on the right side from the steeringwheel.
So in my opinion the best place and the best and of course the cheapest solution.
Thats black velcro on a black dashboard, cos thats my daily mk4, on my black mk4 the dash is wooden, so i have to find some clear velcro for that, i know that it exists, just have to find it.
cheers
Christian
Edited by Christian6N
Velcro.
Christian
My pleasure :thumbsup:
Yeah, i know you were the first who mentioned velcro, i know i know... i just mean that this is my complete solution, means place, velcro and changing the airvent and so on.
Thx anyway Mikey.
cheers
Christian6N
Velcro.
Christian
MK2 dash is perfect, as long as you're left handed or drive a LHD one..
MK2 dash is perfect, you don't have to cover a vent.
As long as you're left handed or drive a LHD one..
