6n2 door cards in a 6n
Could somebody give em abit of information on how to fit 6n2 door cards to a 6n?
I thought i had everything, i've bought the door cards and door handles.
the back two go in fine but when i try to fit the front ones they don't line up.
i was told they're practically a straight fit.
so could someone give me an idea of what needs doing and if possible could domeone post a pic of a 6n with 6n2 door cards please?
cheers
liam
  • Views 2.5k
are you on edition38.com . if so send me your details and ill pm you a step by step guild of how to do it bud . Dave
chande of plan bud i copyed it over to here for you . Dave
hears a rough go at a guide matey,
6n2 door cards into 6N this was done in a car without central locking or electric windows, will differ slightly for cars with these luxury's
you will need from the donor, the door card with as many clips as you can rescue, the tweeter pod with all the fixings and grommets it clips into, the chrome handle and the metal rods for the handle and the lock pin. the window scraper rail that runs along the top of the door, between it and the glass, after the door card is removed. the plastic speaker housing. the water membrane if possible.
* first off you need to remove the 6n door card
* the black inner wing mirror blank (white tweeter pod on 6n2)
* remove the window scraper, you will see the 6n one curves up at the front where as the 6n2 one is completely straight.
* then take off the speaker pod, the 6n2 one is smaller.
* take the black plastic inner door handle off
* remove the door membrane (optional i kept my 6n ones as i didn't have the 6n2 ones)
* you will then need to swap the handle and door pin rods for the 6n2 ones, to do this without braking any of the levers they clip into its easier to remove the lock and then swap them.
* refit the lock and rods (make sure the foam sleeve is on the rod going to the handle or it will rattle!!)
* now its time to move some clips around. where the 6n2 speaker pod is smaller the lower left most screw fixing hole is now redundant, good news though as the hole for the new pod is there anyway (was on mine, may not be on early 6ns??), but it needs the plastic lug from the original hole taking out and pushing into where the new hole will need it. the other 3 are in the correct place.
* another fixing that wont line up with the original is the grab handle lower screw, is slightly lower and to the side a bit on the 6n2. the top one fits fine, if you wanted to leave it like that it holds ok, but its obviously better with 2. luckily the hole is there for the 6n2 fixing, but there is no captive nut in there. so what you need is a 6mm hex nut and some super glue, reach up into the door with the nut, screw the bolt into it a few threads so you can hold it easier without dropping it, glue it in place, wait for it to dry then remove the bolt it should stay there, all ready for when you fit the door card.
* fit new bling chrome inner handle
* fit 6n2 membrane now if you have it
* where the 6n inner mirror blank (black triangle) was, there will be an aluminum 'L' bracket, this will need the rivets drilling out to remove it or the new 6n2 tweeter pod wont fit. use the grommet and screw fixing lug off the 6n2 door and fit the new unit.
now if you want the tweeter to work you will need to wire it to the standard 6n speaker cable in the door, as the 6n tweeters are in the dash, but that's entirely up to you. I've changed my door speakers to 2ways so i have not connected the tweeter.
* fit the 6n2 window scraper
* now, as mine has keep fit windows, after fitting the door card i realized that the window mech is slightly different, as the winder handle would not fit properly as the crank does not stick out far enough and its at a slightly different angle. I've over come this by fitting a set of audi winders and bending the crank to the proper angle.
* fit the door card and you done, much better
cheers buddy, it explains why i've been having so much trouble.
Has anyone got a picture inside the door? I'm trying t fit the 6n2 speaker pods but I cant see how they can fit, I've been trying for the last hour
Doesn't matter now sorted it!!
