can anyone tell me how to fit a open air sunroof?
  • Views 1.3k
Fabric folding roof
Removing and installing fabric folding roof complete
Removing
‒ Remove moulded headlining.
‒ Separate connection on cable drive.
‒ Open fabric folding roof approx. 50 mm.
‒ → Remove clamping frame -1- (24 x Torx T 25).
‒ Pull fabric folding roof with frame upwards out from roof cut-out.
Installing
‒ Insert fabric folding roof into roof cut-out.
‒ → Screw clamping frame onto fabric folding roof (centralize clamping frame in rear corners with both metric torx screws -arrows- then bolt-on from rear, forwards).
Found this for you, shows you the parts you need + there's a few links in there that may lead to something. pretty sure when I re-trimmed my roof linning there was a piece of cardboard suspiciously looking like the same size as my brothers open air roof, I may be wrong here but I think that is the sized cut you need to make to get the unit in. Please look into this first though as I may be wrong.
Link: http://www.clubpolo.co.uk/forum/lofiversio...hp/t255207.html
Edit: thought you meant from a 6n without one in, either way this may help as well as the chap aboves info
Edited by matt01
Thanks a lot guys , you're both legends!! Basicly on mine it's just the fabric, do you know if its gonna be a big job or not?
