2002 9N electrics HELP!
Hi all,
Whilst driving today, I went over a speed bump and then all of a sudden the power steering switched off ABS, engine management, steering and airbag light all came on! The car runs like normal.
I did a scan, cleaned all the earth points I can see (battery, and 2 by the suspension turret), checked the fuses but still no luck.
I cannot communicate with either ABS or airbag module.
After further investigation I discovered that if i disconnect the right bulkhead multi connector (behind the wiper motor), the instrument cluster illumination lights stop flickering and I get the clicking back from the cluster for the indicators!! I am then able to communicate with the airbag controller but not with the engine ecu anymore, until i reconnect the bulkhead connector.
Could this mean there's a short on the CAN in the engine bay?
I am so confused!! Any help would be really appreciated!!
Here are the fault codes that came up:
Address 01: Engine Labels: Redir Fail!
Control Module Part Number: 03D 906 032 T
Component and/or Version: 1,2l/2V SIMOS3 00HS2508
Software Coding: 00071
Work Shop Code: WSC 00342
Additional Info: WVWZZZ9NZ3Y156533 VWZ7Z0B6322678
6 Faults Found:
18056 - Powertrain Data Bus: Failure
P1648 - 35-10 - - - Intermittent
18044 - Powertrain Data Bus: Missing Message from Airbag Controller
P1636 - 35-10 - - - Intermittent
18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
P1650 - 35-10 - - - Intermittent
18045 - Powertrain Data Bus: Missing Message from Electric Load Controller
P1637 - 35-10 - - - Intermittent
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 35-10 - - - Intermittent
18043 - Powertrain Data Bus: Missing Message from A/C Controller
P1635 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
Control Module Part Number: 6Q0 959 433 H
Component and/or Version: 1R Komfortger·t 0002
Software Coding: 00067
Work Shop Code: WSC 00788
Additional Info: 6Q1959801A 1R Tırsteuer.FS TFK 0004
Additional Info: 6Q1959802A 1R Tırsteuer.BF TFK 0004
1 Fault Found:
01336 - Data Bus for Comfort System
80-00 - Single-Wire Operation
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Control Module Part Number: 6N0 909 901
Component and/or Version: 11 GATEWAY CAN 1S33
Software Coding: 00014
5 Faults Found:
01314 - Engine Control Module
49-10 - No Communications - Intermittent
01321 - Control Module for Airbags (J234)
01309 - Power Steering Control Module (J500)
49-00 - No Communications
01312 - Powertrain Data Bus
37-10 - Faulty - Intermittent
Address 08: Auto HVAC Labels: 6Q0-820-045.lbl
Control Module Part Number: 6Q0 820 045
Component and/or Version: Klimaanlage X0840
Software Coding:
Work Shop Code:
4 Faults Found:
65535 - Internal Control Module Memory Error
00-00 - -
01596 - Motor for Outside/Recirculated Air Flap (V154)
55-00 - Adaptation Not Successful
01299 - Diagnostic Interface for Data Bus (J533)
79-00 - Please Check Fault Codes
01317 - Control Module in Instrument Cluster (J285)
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Control Module Part Number: 6Q1 937 049 C
Component and/or Version: 00 BN-SG. 1S33
Software Coding: 25742
7 Faults Found:
00900 - Fuse for Signal Horn (S194)
00969 - Fuse for Heated Rear Window (S41)
  • Views 4.9k
As your problems started after going over a bump in the road, I would suggest that you check the little metal links near the fuses. These can corrode and leave you with an open circuit, or worse (from a fault finding point of view,) an intermittent open circuit. The best way to check these, is to remove them and inspect them, as whilst they are in place, they can appear in tact.
If you find a faulty link, do fit the correct replacement, as these things are actually big fuses and making a 'better' one rather defeats the object!
If you do find that this is the problem, you will also have to clear all of those fault codes and see how things go after that.
Regards.
Also worth checking the battery connections, especially where the distribution block connects to the post. This happened to mine and I ended up spending hundreds on replacing parts and hours of head scratching only to find that the threaded section had stripped off by the vibration of the engine.
HTH
