Leaky Rear Lights
Opened my boot on my mk2 Saloon after a down poor to find that my carpet was wet. Had a quick inspection and found that water looked to be coming in around the top of the lights. Not had chance to have a good look as it yet, just wondered if anyone had experienced this and if so how is it sorted. Cheers
  • Views 745
Anyone ? Before i crack out the silicone ?
Silicone is the way. From experience even new lights and new gaskets still manage to leak. Remove then and clean all parts with white spirit, acetone, alcohol etc to take off all the Dirt. Then put a bead of silicone around the lip on the light then put the gasket over it then put silicone around the openings in the body panel, let it go off for a few minutes then bolt it back on. Go easy on the bolts as they are only set in plastic, and If the silicone is doing its job then it should seal properly without really tightening them.
HTH
Nice one thanks. Id probably of just made a mess with a load of silicone but makes sense spend a little time cleaning it n a small bead shoul do the trick. Cheers
