Preparing the Polo for storage
After a long think its time to retire her for a bit.
There's been a few hurdles to get over and as soon as I'm over one, it goes massivley wrong again.
Sick of the unreliabilty to be honest and its my daily, is shite on fuel, more expensive to tax than the seat 1.9.
The problems this time are more severe, gearbox has got about 25 miles left to live if I'm lucky and I dont think the engine is far behind. Body work needs doing too now.
Costs nearly half my wages every month to fix and I know there's perseverence but I'm too pissed off with it for now.
So..
Aside from removing the battery, is there anything else I need to do before storing? :)
Its gunna be a good year or so I reckon.
Any tips greatly appreciated :)
  • Views 942
Either stick it on axle stands or some tyres you don't care about. Leave the handbrake off (chock the wheels or whack it in gear if there's a chance of it running away. Stick a tray of cat litter inside , leave the windows down a crack if it's inside and the dash vents open to stop the interior going damp.
Don't stop believing!
Pump the tyres up to 40+psi to avoid deforming the sidewalls, take the plugs out and spray some oil into the bores, make sure the antifreeze levels are well up, depress the clutch pedal and leave the handbrake off
Cheers guys..
And Yeti, I'll never stop believing :) Finances just wont allow for Volkswagen reliability!
Drain the fuel is always a handy step
beware of leaving it full of anti freeze as it eats away at head gaskets when put in for storage,I found out the hard way.
all the rubber pipes and seals may perish even slightly so maybe feed em,
edit also fresh oil an filter will help the engine, as alot of nasties get into oil which can damage an engine thats left sitting
Edited by mini_mayhem
Mine's been parked up for a year and i made one big mistake. I parked it off road on the side of the house that doesn't get any sun. It's been damp virtually the whole time.
It was virtually rust free, it certainly is not anymore. And the rear seat's mouldy. As is the front carpet.
None of this bothers me much, but had i left it a few metres away on the other side, it'd be in the far better shape it was only a year ago. Bit of a shame, but whatever.
mines been garaged for 3yrs, dad inflates the tyres every couple of weeks, i came back recently and found the 2 link pipes from the inline pump to the filter into the throttle body perished and leaking fuel.
i replaced them yesterday, and after that it fired into life after re-priming the system.
my only real signs of it being stood is its really dirty and the exhaust has quite a bit of surface corrosion on it, but other than that the shell is still perfect and it runs great now!
definitely drain the fuel from the carb by disconnecting the fuel line and running it til it cuts out.
