Fitting new lock barrel!
Hi all, need some advice,
So someone had a go at breaking into my polo 9n (02 model) by jamming a screwdriver down the drivers door lock barrel!
Bought a kit off ebay to delock the handle, the kit says to loosen the handle you need to slack of one of the two screws on the inside of he door. ( not the interior side but the thickness part of the door.)
Now its a torx screw T40, but it wont come off and I've ended up stripping the head, the other screw goes in and out easy (same situation on the other side)so i know I'm not using the wrong tool it just seems its really tight but the screw metal is too soft, now tried all other methods, i.e. bashing in a slot head, screw extractor?
Any idea wher to go from here?
Know any type of trade which could help??
Cheers in advanced!
  • Views 1k
Can you post a photo of the door shut?
I'm not sure you're targeting the right screw! I've got a secret weapon in the form of a stubby short ratchet screwdriver with a t-piece. Soak in WD40 overnight and then slowly apply pressure whilst pushing down.
However, it's the shape of the screwdriver that really does the trick.
(I'll try to find a similar example on eBay)
PoloD.
Like this:
eBay item: 380174223487
Edited by PoloD
Can't you drill it out and put a new screw in? Or am I being stupid I have no idea about new polos
If a head won't turn initially, or you cant get a full-depth seat into it, put the tool/bit in the head of the bolt and give it a hard firm tap in with a hammer. Then add the wrench and try turning it (and ensure you turn it perfectly square).
This not only gets the bit fully in there, but also shocks the bolt's thread to help release it's grip.
Not that it'll help with a rounded bolt, but it can do if you bash it hard enough with the next size AF version. Otherwise, another way is to cut a huge slot in the head all the way down through the head with a disc grinder, and use a huge flat head screwdriver.
Cheers for the advice guys,
PoloD I'll have a look at that method. And there's only two screw/bolts one at the same level as the lock barrel and close to the outer door - the other is a small length an is used for the door latch part
I don't have the expertise to drill it out ha
The head is completely stripped and I did bang a wide slot head into the metal but it went in and turned the metal.
Metals really soft. Maybe going deeper is sn option like you say but dunno if i could put that bit of kit up against my car haha.
But since I spoke to my mate who's a HGV mechanic and he said the same sorta bolt is fitted to the trucks as a anti theft/ thief deterrent! Basically there not easy to get off so you can't just easily change the locks.
So he recommended a sharp chisel and tsp it round?
Cheers again I'll have a variety of attempts then ha.
Managed to get it out using a hammer and filed down slot head (DIY chisel ha)
Cheers for the advice guys again, was all glued in do heat should of helped :)
