towbar talk
looking to get a towbar fitted to my 6N2, i assume a 6N towbar will fit also??
  • Views 1.5k
Anyone?
6n2's might come under the new tow bar rules which means it is also part of the MOT.
If the tow bar mountings are the same then there should be no reason for it not to fit, unless the different bumper shapes mean the tow bars are spaced out slightly differently to clear the body work.
the next problem you might get is that the wiring might be slightly different, some cars need specific looms for the towing electrics to work, just splicing wires doesnt work any more as it could cause other electrical issues (warning lights, blown bulbs, alarm system).
Any vehicle fitted with a tow bar is now part of the MOT
If you have fitted the 13 pin "Euro socket" for the electrics that is also now tested for correct wiring of position/side, brake & fog lights.
The 6n2 is still a basic wiring setup, so you can just use the auxillary connections on the rear light holders to run the wiring to the trailer socket
wiring it in is now bother, have done all mine so far, but I'm struggling for confirmation if the towbar set up 6n is the sale.
If i search, some companies list them from models 92-2002 e.g. http://www.just-tow.co.uk/vw-polo-hatch-1994-2002.html
