Spray Adhesive
Anyone have any recomendations? Preferably from people who have used something a while ago and its still stuck! Have used spray adhesives before, but they tend to either come out in a piss thin streak or they dont tend to last too long. Anyone from the 'industry' have any recomendations?
Ta
  • Replies 23
  • Views 1.9k
We use contact adhesive at work, so you spray on each surface & let it go tacky and it's awesome, I can't remember the brand though :/ definitely worth spending the money, do 3m offer anything?
i used wickes carpet adhesive and everything is still stuck down nearly a year on. its pretty cheap too
Are they both sprays? 3m do do something, are they the daddies then? Ideally would like a bit of adjustability once the fabric is in place, something contact doesn't allow.
Pritt stick?
I done my headlining in my 6n with some stuff i got off ebay called trim fix it was in a silver and red tin .. Done that about this time last year and is still good .. If u do use it.. dont use it inside as its hard to get off tables and carpet
wickes stuff is made by bostik, flooring spray adhesive and contact adhesive are good.
Have been reading through loads of previos posts about retrimming headlinings this morning, are these products likely to go straight through say printed bedsheets?
50/50 PVA glue with water. That's what I'm using for my sub box
I work for a caravan company and we use a product called sta-put
Does what it says on the tin lol
Thank you. Exactly the input i was after.
Thanks to everyone else too. I'll have a search for all of the above products
Where might i get some Sta put?
Best would be google sta-put adhesives near where you are
I think worth do a similar product to
Just bought some Wurth stuff. Its a contact adhesive, but I'll see how i get on with it.
have to see whether its wurth it :)
just read through these posts and no one has asked what hes sticking? what kind of fabric/trim is it? I've built loads of custom ice installs in my time and have found the autoleads spray adhesive to be very good and lasts,but it was no good when we were trimming bits with vynal or leather look materials so we used a contact adhesive for that, all depends what your sticking, if your carpet has a backing then spray adhesive will work but wont last all too long. when using spray adhesive remember to give a good even coat over your pannel then leave for a minute or two for it to go tacky before sticking otherwise it stays too wet and the solvent escapeing makes it peal back off
Thanks for that. I'm sticking vinyl material that has a fabric backing and tweed
you may be better with a contact adhesive then, the spray adhesive will stick the vinyl but wont last too long, never worked with tweed so wouldnt want to comment but contact adhesive would be the way to go with your vinyl
Cool, thanks for that. I have contact too, just wanted a little bit of leeway when gluing it down. Best get it right 1st time!
Ta
I've got some stuff at work that we use for sticking down floor tiles (in a heavy use office) If you are looking at carpeting etc this might be just your stuff as I've never had a tile come up (without a lot of force) I will try to pick a can up tomorrow to get the brand name as I can't remember it. but I don't give any promises for vinyl as the solvents may ruin your project. if I remember the instructions correctly it may be a spray on impact as I think I had to let it dry to tacky before assembly.
Anyway brand name tomorrow.
Phil
WURTH's stuff is very good. For the vinyl I would use the spray adhesive and for the tweed I would use there contact adhesive ( I think that's what it's called), it's in a small pot and has a brush in it, this stuff will stick your shoes to the floor so be careful with it. Both take a couple of minutes to go off so what I do is apply it to both surfaces and wear latex gloves, then take them off and let the glue go off a bit then with your clean hands place the material how you want it. This way you get it how you want and don't get it dirty. Also for spray adhesive the wicked stuff is also pretty good.
HTH
One of those just opened up near me. Maybe I'll check it out. Cheers
Ta
Sorry it has taken so long but could not find your posting. The stuff I use at work is called "supastick" Don't know where you can buy it but can provide a link to website who seem to be the manufacturer. have not tried to buy it yet but will need some soon myself as I am on last can.
http://www.aft-ltd.com/productdetail/supastick.php
hope it helps
Phil
Thanks phill. I have some wurth stuff on the way, and I'll see how that goes. May try some supastick too
