6N2 lower dash removal
Hello,
I need to remove the lower driver side dash trim. I undid the obvious screws and could get the black bit off above the pedals but I need to get the section above that off. I undid 6-7 screws in total but it wouldn't budge. I had to stop as it was raining and I had the doors open but if anyone that's removed these could give some advice that'd be great.
Stu
  • Views 6.4k
  • Removing – Release steering wheel height adjustment -1-. – Move steering wheel to highest position. – Remove bolts -arrows-. – Take off lower steering column switch trim -2-
Removing
– Take off lower steering column switch trim -2-.
– Remove bolt -1-.
– Take off cover -2-.
– Remove screws (6 in total) -arrows-.
– Remove driver's side storage compartment -3-.
Installing
– Installation is carried out in reverse order of removal
Balls,
I put the 3 screws in from the ignition surround (after leaving them out from when I replaced the wiper stalk), then removed all screws apart from the one at the far right in image 3. Ah well I was almost there - will try again tomorrow. Wouldn't have thought to release the height adjustment though.
Thanks for the help - will post up how I get on.
Thanks for that - got it done today.
