6n2 interior in 6n
hi
just researching for future plans I guess
basically as with most show/custom cars I am planning on a full interior re-trim on my 6n in the future.
so as I was thinking about it I thought about fitting a 6n2 dash as I know that can be done but after looking into it I have noticed it doesn't line up with the moulding of the door card as it would in the mk5.
so basically I want to know how much of the mk5 interior goes into a 6n? mainly the door cards
any help is greatly appreciated :) thanks in advance
Callum.
  • Views 1.3k
The entire interior from a 6n2 goes into a 6n
If you are changing the dash you will need to change the door cards (front and back) as they will not line up. If you have electric windows you will need to change the door looms as well as the complete dash loom (I'm sure this isn't straight forward) because the 6n2 uses window switches in the doors not in the dash. Tbh I'd you seriously thinking of this then I would go to an auction and get a damaged 6n2 and just transfer everything over. This would be ALOT cheaper and so much easier then removing bits from a breakers yard , going all the way home only to realize you forgot something important. And you could bet that they will charge you double for that last part.
HTH
