opinions on this texture as my headlining
  • Views 689
You won't be able to shape it into the bends...
You could get it round edges etc but you would have to heat it up, this is a little tricky because you have to heat up just enough of the area your shaping other wise it will distort the texture and become smooth. Best to try a small part first ie pillar trim before diving in with the headliner. Although, is 60" wide enough?
HTH
