gearbox on a gt
what gearboxes can i run on a gt engine? which ones are the best? obv. the gt box, but what other solutions are there?
how will the 1.0 4 speed run?
how will the 1.3 5 speed run?
any others?
  • Replies 25
  • Views 1.6k
Iv run a 1.3 5speed and after the gt box that was on it i found the ratios too long tbh which made it feel sluggish. IIRC g40ad ran a 4 speed on the taxi, and apparently it went like fook :lol:
Edited by Tramp
ran a 4 speed on a taxi? he had a polo taxi? lol
nah it was his gt, named the taxi :lol: Cant find the thread now, but i know it was on a 4speed box ;)
The 8p runs well on the GT, I've got one for sale if you need one ;)
^ It really doesn't, an 8p gearbox is fine on G40's though.
I've been lied to then! ¬_¬
ha ha i was looking for a gearbox actuly! i guess i should stay away from the 8p's! ta kerrly
8p box on a GT would be fine just not as fast accelerating in the higher gears, the tradeoff being better fuel economy. It will harm the performance quite a lot though. It's better to stick with a GT box unless you increase the displacement (1.4/1.6 conversions)
Forget 4-speeds they are all moreorless the same as the 8p just without 5th gear. They work, but again performance is hampered. People have said otherwise in the past but I really can't see the advantage.
how bad would it hurt the fuel economy? other than ratios, is the GT box any different?
The 8p box gives BETTER economy. It has longer ratios than the GT box, so the revs are less high in top gear so therefore uses less fuel.
Would the GT box bring the revs down at motorway speeds when fitted to a 1.0? Or would i need the 8P? as i'm thinking of changing to 5 speed, to make my car rev lower and be less noisy at motorway speed.
It's totally a matter of preference.
I couldn't run a GT gearbox, the ratios are short so they're good for absolute acceleration at any given time, but you have to keep changing gear to sustain it, plus you run out of gears once up to speed so the engine runs fast, and this kills economy.
The 1.0 gearbox is much the same.
The 8P's longer gearing means less acceleration in gear, but each gear will go further and faster. Plus high speed will be more relaxed, quieter, less wear on the engine and it'll give better economy.
I'd prefer a gearbox even longer tbh, but an 8P was fine in my 1.3 MH, i'd fettled that a little but it was running less power than a GT.
Still, i prefer longer ratios, you soon get used to acceleration but it's always nice to have the gears go further and keep fuel use lower.
When using a 6n 16v as a commuter, i hated the valver gearbox so much i pulled it out and put a long ratio unit in. Still went great in real terms, as i wasted less time changing gears.
Like the GT, it was an engine that needed revs to get the best out of it, but this still works in long ratio boxes - you just use lower gears when you wanna nail it.
ahhhh i dont know what box i want now! i like the sound of fuel economy and less noise and stress on the engine at high speed, but i also like the sound of the acceleration of a gt or 1.0 box!
much thought is needed!
I wouldn't get to hung up on MPG from a 1.3. Fit a GT box and give the car hell!
is it actually any different other than the ratios?
across the polo 1-3 range and some golf boxes too and others i expect, the boxes are inter-changable. but the internals vary a little like ratios, and final drive, and also different types of differential fitment, ie. gt and g40 diffs are bolt in the others are generally pressed, so an aftermarket diff will only go in the bolt in type.
if your not worried about diffs, then the ratios are the only thing you need to consider (and of course making sure the gearbox is definitely one of the early inter-changeable types).
8p boxes suck. feels too long even on my afh. the only good thing about it is the 5th gear.
i want a gt box with 8p 5th gear. would be perfect! then again I'm the kinda person who loves blasting through the gears
The GT box and 1.0 4-speed box have very similar top gears so there would only be a very slight improvement. Some 4-speed boxes (usually fitted to 1.05s) have a shorter final drive than a GT box, which also increases revs over a GT box.
My 1.05 mk2 has a 5-speed box. It's shorter than a GT box but it feels fine on the motorway doing 70-80. I am running big wheels though, and I have a standard exhaust, so it's pretty quiet.
can you not just remove the final drive from an 8p and swap it for the final on a GT box?
They are the same. Also, you can't swap it. Only the 5th gear can be swapped easily.
My DCC box (1.6 8v) was sweet for economy but I could pull 80mph in second, it was pointless.
Then tried a 1.4 8v box which was better, now on a 1.3 8v 6n box, same ratios as a valver apart from 5th is a bit shorter, I think it's similar to a GT box too.
It's bought the car to life, third gear is SO much better than before, but now the top of 4th is where the top of 3rd was (third was 67-106mph, limiter in second to limiter in 3rd) but yeah now 4th tops about 120.
May go for the swap of fifth though, doing 4000rpm at 80 now, bit annoying!
4000rpm @80 is the same as my 8p. running small wheels though obviously
I love my cool 2100rpm @ 80mph 8-)
My DCC box (1.6 8v) was sweet for economy but I could pull 80mph in second..
..third was 67-106mph, limiter in second to limiter in 3rd..
Bit confusing, did second hit the limiter at 67 or 80..? Where does the limiter kick in at? What tyres were you running? What did you have for breakfast this morning?
Yeah, but that's like halfway through your rev range :lol:
i think I'm going to run a 1.0 4 speed box on a gt engine, does anyone know if there will be any trouble fitting the drive or clutch or anything in?
