Alignment issues :/
Okay so I have a 9n, I bought this car quite a while ago, but I have only just hpi'd it as a friend does it for free and turns out my car was cat d write off in 2008, so I did some investigating and turns out it must have been crashed into, on the front passenger side wing, I have noticed it is very badly misaligned (didn't realise before because never paid much attention to the car) but basically my question is, the main problem is the passenger side inner wing has been bent towards the engine and the driver side has bent the same amount in the same direction, is there anyway of fixing this without putting it on a jig ? It dosnt have to be absolutely perfect, just be a bit straighter
Any help is greatly appreciated
Liam
P.s. I didn't pay much atention to it as I hadn't passed my test at the time of buying the car and couldn't afford insurance, so has basically been sat waiting for when I can afford to drive and have a licence :)
  • Views 755
You could try an old-fashioned drop test to find out how far out of alignment it really is:
Car needs to be on a level (ish) smooth surface.
Working on known undamaged areas (in your case, maybe from the middle of the car and towards the rear.) Use a plumb-bob on each side of the car in EXACTLY the same place (suspension mounting points etc.) on each side. Under the tip of the plumb-bob, apply chalk to the ground and then VERY carefully, with a pencil, mark the EXACT place where the plumb-bob points to, onto the chalk. (A chalk mark directly onto the floor is not accurate enough).
Repeat the above in as many places as you can on the undamaged part of the car.
Now continue this process in the damaged area.
Taking care not to contaminate the markings on the floor, move the car away.
Working on the UNDAMAGED area as marked on the ground, carefully measure between chalk marks where each side of the car had been.
Divide the results by two and again, very carefully, using the same method,mark this on the floor.
Now, with a chalk line and a couple of assistants, mark the centre-line on the floor, continue this through the damaged area.
If you now measure from where the damaged area was to the centre-line, you will be able to see how far out of alignment the car actually is.
With the engine, suspension and may be the front wings removed, using some sturdy timber, you would find it surprisingly easy to bent the chassis back into position, the problem being, in the absence of a jig, is getting it right first time.
If you go ahead with this, you really should replace the front suspension, as without non-destructive testing, it is just about impossible to check for cracks and distortion can be hard to judge.
Regards.
Usually, when the wing is pushed inwards from the outside it flexes up and inwards towards the engine. What it sounds like is someone has just unbolted the old wing and then bolted a new one on straight away. What they should have done is straighten the fletch panel before doing this, as when the Wing is unbolted this part is very weak. What you can try is loosening the 10mm bolts and easing the wing outwards, then while holding the Wong under pressur, tighten the bolts. Close the bonnet and look at the gap between the wing and bonnet. This should be the same distance at the top and bottom(front and back) you might have to do this a few times to get it right. It's also likely that your front panel is out as well. You can check this by looking at where the bonnet meats the grille and lights, again this should be even.
If you could put up a picture of the inner wing area it would make it easier to help, although try the above and see if that helps.
