Mk2 golf rear door handles on mk2 polo (De-locked)
Tools needed:
Screw drivers (flat and posi)
Pliers
Small punch (i used a smallish nail)
Small hammer
Small round hole file
Picked up some mk2 golf rear door handles today which get rid of the door key locks as i have fitted central locking to my polo and someone had attempted to open my car with a screwdriver through the door lock :/, so thought id write up a little guide on how to fit them
1. pop off metal covers, as you can see you just pop them off with a screw driver
2. remove screws holding handle in place one is next to the door catch one is behind the metal cover, once the screws are out push the handle towards the front of the car and pull them out
3. as you can see the inner levers are different so will need swapping over, to do this you will need to push the little pin out (picture below) of all 4 handles, remove the levers and swap them over, using the pliers, push the little pins back in, at this point i used some wd-40 to make sure all moving parts were nice and free
4. once you have done this
the handles can be re-fitted, if you have bought new handles you will more than likely get new gaskets with them, these wont be any good you will have to use the polo ones as the golf ones are fatter and the holes wont line up for the screws, the screw behind the cover will go straight in but the one by the door catch wont, if you offer the handle up to the car you will se how far out the hole is, i used the hole file to elongate the hole slightly, you will find the screw has to go in at a slight angle but once tightend you wont notice.
5. pop the metal cover back on and admire your handy work ;)
Before
After
  • Views 3.2k
Good stuff, i knew about it but i've never seen a guide with photos.
I think the locking ones look better (as long as they're not mangled), so i've just disabled mine, but then i'm weird like that.
yea this is why i changed that as you can see in one of the photos someone tried breaking into my car with a screw driver lol
Nice little guide.
Ahh bugger I've just realised theres already a guide for this i searched in the faq section and couldnt see it but I've just noticed it pinned at the top lol
Edited by DanIOW
Last time I did this I, I just removed the barrel from the polo front handle and fitted the golf plastic casing over the existing mech.
Which reminds me I need to get a new mech for my O/S rear on my Mk1 Golf.
Proves how much i keep up with pinned topics.
Alex's guide is excellent, to be fair it's only been there two months, i was expecting to see it being a 2006 job.
