Some help with fibreglass
Hi all,
I am in the process of making some speaker pods for an audio install. I have got the precut speaker rings and have made up all the parts from wood. My question is , would I need to us the fibreglass woven matting? Or could I use other material and cover that in resin? I only ask because I have been reading up on doing this for a while and most people use old t shirts or similar material and not the fibreglass matting. What's the difference? Will one last longer then the other? Also if I was to use natural instead , could I use the same resin as fibreglass resin?
Have searches this forum but not much has come up for this. I have also asked in other audio forums but thought I should also ask the good people of club polo.
I haven't ever used fibreglass for this type of thing before so Its a learning process for me.
Any help will be appreciated
Edited by dixy
  • Replies 11
  • Views 1.2k
i used a t shirt ..the advantage is you can pull it tight and stapple it then use the fibre glass mat aftrwards to thicken it up on the inside
I'm thinking about doing a boot install out of fiberglass. Watch you tube thats what i have been doing :)
How have you gone about building the template for the resin? Do you have any pictures?
I made some up a while ago but they came out pretty bad lol so am gonna have another crack at it.
My old uncle used to tell me that, before glass fibre/resin was even invented, he used to laminate old lace curtains with coach varnish. He claimed that this was as least as good as glass fibre. What he didn't say, was just how long this stuff took to set!
Thanks for the replies guys.
So I should get some matting and resin, and then find an old shirt to use. Any advice on what type of material works better, or are they all the same? I've read that fleece works well?
gaz- I jus bought some precut speaker rings and I have made a cutout that will fit flush to the door panel and bolt into the old holes. I'm thinking to maybe use some pieces of thick dowel rod cut to length then glue the rings to the backing cutout? But i m not sure yet. I guess then after its sturdy I will stretch material over it then put resin onto that, but again not sure yet.
I'm making this because the speaker are way too big to fit into the original holes so I have to make this.
Again thanks for the help guys!
i have done many boot builds in my time the best thing till use is fleece to stretch over the wood template soak it in plenty of resin then add a layer of fiberglass matting 1 layer of 300 and a 450 over top then soak in plenty of resin make sure you soak it all fully and soak round the edges so you can trim the excess of when fully cured the you can sand it down and prep it of paint of over it in material
here one i made earlier lol
Nice work buddy, did you make a wooden frame, or is the bottom a flat piece? Looks professional.
So is 300 and 450 different grades of matting?
yeh id use a t shirt to get the shape, and then the fibreglass matting, and then body filler to smooth it all off.
thats cus i am a professional lol :-) yeah a wooden fame then made MDF rings for the speakers the propped them up at angels the stretched the material over them them fiberglassed them and yeah they are diffident grades of matting
Edited by doyler
My work shirts are thick and stretchy, polo shirts like rugby tops but cheap polyester. Dunno where you'd get them from though.
Industrial clothing suppliers i guess, where you'd get overalls.
Or just nick your other half's lycra tops.
have built more ice installs than i care to remember, tried and tested many ways of doing what your doing and found the best stuff for the job to be acoustic carpet, the same stuff you buy to cover the sub boxes, it stretches nicely, can be stapled down, over lapped and shaped to make yor install and is thicker than a t-shirt so needs less layering once its set, the autoleads stuff seems to be best as it stretches a fair bit
